freestyle Napisano 28 Czerwca 2011 Napisano 28 Czerwca 2011 witam! Chcę kupić rower i zaciekawiły mnie dwie oferty: kross level a2 Opis produktu Rama Aluminium 6061 Kolor czarno-biały; biało-pomarańczowy Rozmiary 17'';19'';21'' Widelec SR Suntour SF7-XCR Biegi 24 Przerzutka przód Shimano SIS Przerzutka tył Shimano Alivio Hamulec przód Tektro 836AL Hamulec tył Tektro 836AL Manetki Shimano Alivio Korba Shimano FC-M191 Suport Kaseta Alfred Thun Łańcuch Shimano CN-HG40 Kaseta Sram PG-830 8-speed Piasty Joy Industrial Opony Trax Trail Trax 26 x 2.1 Obręcze Mach 1 EXE Damper - Kierownica HL Corp aluminium Wspornik kierownicy HL Corp aluminium Wspornik siodła HL Corp aluminium Stery Super Express H-142 Siodło Selle San Marco BLAZE Pedały NATTY CS-90KA Waga 14kg schwinn mesa Rama: Schwinn N'Litened Silver Label Custom Drawn Aluminum with Trial-Tuned geometry, Epicenter seat stays, replaceable hanger and disc brake mount. Widelec: SR Suntour XCT Aluminum lowers, Coil Spring with friction damping, pre-load adjustment, bootless, 80mm travel Korba: SR Suntour XCC-T202 42,34,24 hardened steel chainrings Suport: VP sealed cartridge square taper with chainline stabilizer Pedały: ATB Resin body, Boron steel axle, Steel cage. Toe-clip adaptable. Przerzutka - przód: SR Suntour XCM202 31.8 dual pull Przerzutka - tył: Shimano Alivo RD-M410 Manetki: Shimano EF-50 Easy Fire integrated shifter / brake lever Kaseta/Wolnobieg: Shimano CS-HG30 8-speed cassette 11-32 Łańcuch: KMC Z-72 Obręcze: Alex PC-19 double wall alloy with finished sidewalls to improve wet braking, 32H Opony: Kenda K 1027 26" x 1.95" Piasta - przód: Formula Alloy Weather Sealed with alloy QR Piasta - tył: Formula Alloy Weather Sealed QR set with Cassette 8-speed rear Szprychy: Stainless steel 14 gauge with brass spoke nipples Hamulec p/t: Pro Max Linear Pull with 64mm pads and linear springs. Klamki: Shimano EF-50 Easy Fire integrated shifter / brake lever Kierownica: Alloy 6 degree bend, 600 wide Mostek: Trail Tuned, cast alloy threadless 15 degree rise with forged front load cap. Gripy: Lock-on double density Kraton Stery: VP 1 1/8" sealed Siodełko: Trial Tuned super soft with two tone cover Wspornik siodełka: Forged Alloy, micro adjust 26.8 x 350 Extra: Alloy Low-Profile QR with forged clamp Niestety nie znam się na osprzęcie i trudno mi porównać te dwa rowery. A może macie jeszcze jakieś inne propozycje? (najlepiej do 1300zł)
brt0555 Napisano 28 Czerwca 2011 Napisano 28 Czerwca 2011 A2 level wypada lepiej, jak masz mozliwosc kupna takiego do 1300zlt to warto. Jeszcze mozesz spojrzec na unibike evolution z 2010 roku, tez ciekawa opcja.
freestyle Napisano 28 Czerwca 2011 Autor Napisano 28 Czerwca 2011 Niestety unibike poza moją kieszeń. Na tego schwinna znalazłem przecenę z 1840zl na 1290zl dlatego pomyślałem że to byłby dobry deal, ale z tego co czytam to rzeczywiście ten kross jest całkiem dobry. Dzięki za szybką odpowiedź!
