Bzzyku Napisano 19 Września 2010 Napisano 19 Września 2010 Witam wszystkich Potrzebuję pomocy w wyborze roweru: # Specialized Rockhopper SL PRO (2010): Widelec Rock Shox Reba SL, Dual Air, 80/100mm travel, 1 piece magnesium lower, 32mm alloy stanchions, alloy steerer, Motion Control damper, rebound adj. w/ LO, disc only Stery 1-1/8" threadless, Campy style semi-cartridge bearings Mostek 3D forged alloy, reverse 4-bolt, 7 degree rise, 31.8mm clamp Przedni hamulec Avid Elixir 4 hydraulic disc, alloy backed organic pads, 160mm G3 Clean Sweep rotor Tylny hamulec Avid Elixir 4 hydraulic disc, alloy backed organic pads, 160mm G3 Clean Sweep rotor Klamki hamulcowe Avid Elixir 4 Przednia przerzutka Shimano Deore, 34.9mm clamp, top swing, bottom pull Tylna przerzutka Shimano RD-M772 Deore XT Shadow, long cage Manetki Shimano SL-590 Deore trigger Kaseta Shimano HG50, 9-speed, 11-34t Łańcuch KMC X9SL w/ reuseable Missing Link Mechanizm korbowy Shimano FC-M532, 2-piece crank Wieńce 44A x 32S x 22S replaceable Suport Shimano FC-M532, integrated outboard bearing design for 2-piece crank Obręcze DT-Swiss 445D, 26", alloy double wall disc, pin joint, eyelets, 28h front and 32h rear Przednia piasta Forged alloy, hi/low flange, sealed cartridge bearing, machined disc mount, 28h Tylna piasta Forged alloy, double sealed cartridge bearing, machined disc mount, cassette, QR, 32h Przednia opona Specialized Fast Trak LK Control, 26x2.0", 60TPI, tubeless ready aramid bead Tylna opona Specialized Fast Trak LK Control, 26x2.0", 60TPI, tubeless ready aramid bead #Specialized Rockhopper PRO (2011): Wielec RockShox Recon Gold SL, magnesium lower, 1-1/8" alloy steerer, 32mm alloy stanchions, solo air spring, Pop-Loc remote LO, external rebound adj. Stery Integrated 1-1/8" threadless, Campy type full cartridge bearings Mostek 3D forged alloy, 7 degree rise, 31.8mm clamp Przedni hamulec Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep Rotor Tylny hamulec Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep Rotor Klamki hamulcowe Avid Juicy 3 SL hydraulic Przednia przerzutka Shimano SLX, 34.9mm clamp, top swing, dual pull Tylna przerzutka Shimano XT 10sp Shadow Long cage Manetki Shimano SL-M660-10, SLX rapid fire Kaseta Shimano HG81, 10-speed, 11-34t Łańcuch Shimano HG74, directional Mechanizm korbowy Shimano FC-M552, 2pc., cartridge bearing outboard BB Wieńce 44A x 32S x 22S replaceable Suport Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm Obręcze DT-Swiss 445, 26", alloy double wall disc, pinned w/ eyelets Przednia piasta Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 28h Tylna piasta Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h Przednia opona Specialized The Captain Control, 26x2.0", 60TPI, tubeless ready aramid bead Tylna opona Specialized The Captain Control, 26x2.0", 60TPI, tubeless ready aramid bead Różnica w cenie wynosi 200zł na korzyść modelu na 2010, więc nie gra ona roli. Jak najszybciej muszę dać odpowiedź, bo wybór rowerku zamknął się między tymi dwoma modelami
