Andrew Napisano 21 Października 2008 Napisano 21 Października 2008 Siemka! Jeżeli jest wśród Was ktoś dobry z angola i chce się chwilkę potrudzić, to mam dla niego ZADANIE BOJOWE. Tekst tyczy się opisu przeróbki kartridża TST2 w marcoku : 1. It all started with an MTBR post asking for help on how to set up a Mazocchi 55 TST2 fork...And turned into a complete damper modification. The problem I was having was high speed spiking. With the help of Flyag1 (he cracked open his damper cartridge and set me the pics) we were able to figure out that the damping was a port orifice design. The port orifice being the source of the high speed spiking. But from Flyag1's pics I also noticed something else; a blanked off potential compression piston. This compression piston was simply blanked off with just some thick washers. I speculated that we could replace the washers with a shim stack with the lock-out orifice acting as an adjustable bypass port. Sounds great, but modifying my new 3 year warranteed fork on some pics and guesswork was pretty racy for me. Then I got the dreaded hydro-locking damper cartridge - a week before Sea Otter (I was entered to race). And Marzocchi Tech Department replied to my post with confirmation of our guesses and additional great info, to give me the confidence I needed. I knew I had to crack open the cartridge to be able to run the fork for Sea Otter. I figured, if I'm in there I may as well give the damper mod a shot. I had my spacer ready, shims ready, beers ready... 2. Damping was controlled and felt as normal (pre-mod) with trail riding at wide-open. Then I stuffed the front wheel straight into the boneyards at speed; the smaller stuff was simply erased, 3" or larger squared rock stills had some feedback, but it was controlled and not spiked feedback (and could be related to spring ramp-up). It did make my rear shock seem less plush - not a technical issue just a feel issue. End of DH rock run, my hands were not killing me as they were prior to the mod. I did still have some arm pump, but that is expected on that particular trail. Drops and jumps seemed to go just a bit deeper into travel, (spring rate or less HSC?) but the ramp up of the air spring still gave that lovely landing-on-a-couch feel, and covered any mistakes. Lock-out is now a compression adjustment. Full lock out is firm compression (port orifice is off and piston/shim is active) that makes the fork only move about an inch under stand and pedal situations (2 inches max when stand and mash is tired and sloppy). The cool part this this retains 80% of the lock out benefits, but the travel remains well controlled and active - still eating up small and large features. I will never have to worry if I am locked or not on a downhill, as it is still perfectly rideable on "full lock". So am I happy? Hell yes! It is now the fork I thought I bought and wanted. I love that I can also easily modify to shim stack to shape the compression to my riding. I am using a quarter turn compression setting to give an nice controlled and efficient feel on XCish and flowy trails - it also helps with dive. (just a quarter turn gives me full shim stack only compression)
