Proszę o wycenę zakupionego jako nowy roweru Fuji SST 2.0. Stan idealny.
L (56cm)
MAIN FRAME: C-4 UD carbon, Integrated head tube w/1 1/4" lower, Aero seat tube, Internal cable routing, Oversized PIIS BB shell, Double water bottle mounts.
REAR TRIANGLE: C-4 carbon thin seat stays, Oversized chain stay w/ETC and forged Aluminum drop out w/replaceable hanger
FORK: FC-440 Carbon Monocoque w/RIB Tech, Tapered Carbon steerer & carbon drop out
CRANKSET: Shimano Ultegra Hollow Tech II, 34/50T
BOTTOM BRACKET: Shimano Press In Bearing System
FRONT DERAILLEUR: Shimano Ultegra, F-Type-Braze On Mount
REAR DERAILLEUR: Shimano Ultegra, 10sp
SHIFTERS :Shimano Ultegra STI shifter/brake, 20-speed, Flight Deck compatible
CASSETTE: Shimano Ultegra 11-28T, 10sp
CHAIN: Shimano Ultegra, 10sp
WHEELSET: Oval W-530 Aero Alloy Clincher Wheelset, 30mm rim - 700c
BRAKE SET: Oval RB-500 Forged Alloy Dual Pivot w/Cartridge Pads
BRAKE LEVERS: Shimano Ultegra STI
HEADSET: FSA No. 42 1 1/8"U- 1 1/2"L Integrated, w/Alloy convex topcap
HANDLEBAR: Oval R-700 DB Alloy, 31.8mm
STEM: Oval R-700 Alloy 31.8mm, +/-6 degrees
TAPE/GRIP: Fuji Custom Micro-fiber wrap
SADDLE: Oval SR-700 Sweep w/ Ti Rails
SEAT POST: C-4 Aero Carbon w/ Ritchey Clamp System
