Który rower waszym zdaniem lepiej wypada :
Orbea Alma H50 29er 2018
https://www.orbea.com/gb-en/bicycles/alma-29-h50-18
SPECIFICATIONS AND OPTIONS FRAME Orbea Alma Hydro 2018 Triple Butted 4X4 Taper PF Race FORK RockShox 30 Silver TK 100 Air Remote CRANKSET OC-Custom PW Vortex-501-TT 22x36t HEADSET FSA 1-1/8 - 1-1/2" Integrated HANDLEBAR Orbea OC-II Flat 720mm Race Face Ride Flat 710mm Kit (Bar+Stem+Spost) STEM Orbea OC-II SHIFTERS Shimano Deore M6000 BRAKES Shimano M365 Hydraulic Disc Shimano MT500 Hydraulic Disc CASSETTE Shimano HG50 11-36t 10-Speed REAR DERAILLEUR Shimano SLX M670-D SGS Shadow Direct Mount FRONT DERAILLEUR Shimano Deore M6020 31,8mm CHAIN Fsa Team Issue WHEELS Mach1 Traxx 21c Tubeless Ready TYRES Maxxis Ikon 2.20" FB 60 TPI Dual PEDALS N/A SEATPOST Orbea OC-II 27.2x400mm Orbea Digit 27.2x400mm SADDLE Selle Royal Seta Sport Selle Italia SL XC Flow
Specialized Rockhopper Expert
https://www.specialized.com/gb/en/mens-rockhopper-expert/p/128928
CHAIN KMC X9EPT, 9-speed, anti-corrosion coating w/ reusable Missing Link™
BOTTOM BRACKET Square taper, 73mm, internal bearings
CRANKSET Stout, forged alloy, 3x9
FRONT DERAILLEUR Shimano Altus FD-M371, 34.9mm clamp, down-swing
SHIFT LEVERS Shimano Acera 3x9
CASSETTE Sunrace, 9-speed, 11-34t
CHAINRINGS 44/32/22T
REAR DERAILLEUR Shimano Deore, 9-speed
WHEELS
FRONT HUB Shimano Center Lock, disc, 100x9mm QR, 28h
REAR HUB Shimano Center Lock, disc, 135x9mm QR, 32h
INNER TUBES Presta, 40mm valve
SPOKES Stainless, 14g, black
RIMS Stout XC 25 29, alloy, disc only, double-wall, 25mm internal width, 28/32h
FRONT TYRE Ground Control Sport, Flak Jacket flat protection, wire bead, 29x2.3"
REAR TYRE Ground Control Sport, Flak Jacket flat protection, wire bead, 29x2.1"
COCKPIT
SADDLE Henge Sport, steel rails, 143mm
SEATPOST Alloy, 12mm offset, 2-bolt clamp, 30.9mm
STEM Stout 3D-forged alloy, 31.8mm, 6-degree rise
HANDLEBARS Stout double-butted alloy, 10mm rise, 10-degree backsweep, 4-degree upsweep, 720mm width, 31.8mm
GRIPS Specialized MTB Grip, lock-on
SUSPENSION
FORK SR Suntour XCR-Air 29, rebound adjust, air spring, tapered alloy steerer, QR, 80/90/100mm travel (size-specific), 51mm offset
BRAKES
FRONT BRAKE Shimano BR-M315, hydraulic disc, resin pads, 180/160mm rotor
REAR BRAKE Shimano BR-M315, hydraulic disc, resin pads, 160mm rotor
ACCESSORIES
PEDALS Specialized Dirt
FRAMESET
SEAT BINDER Alloy, QR clamp, 34.9mm
FRAME A1 SL Aluminum, Sport XC 29 Geometry, tapered head tube, internal cable routing, 135x9mm forged dropouts, chainstay-mounted disc brake, replaceable alloy derailleur hanger
* Specifications are subject to change without notice
11 godzin temu, Dezent napisał:
Jasne, że Orbea.
Co jest przewagą?
Firma oferuje rozmiar M z kołami 27.5 oraz L z kołami 29 co wybrać przy wzroście 180  cm ,noga 83 cm.
