Napisano (edytowane)
Witam, prosze o wycene.
Z tego wzgledu ze rower ma byc wytawiony na sprzedaz w innym kraju spec roweru po angielsku.
FRAME
Enduro M5 alloy, fully manipulated frame w/ ORE TT and DT, forged HT, sealed cartridge bearing pivots, ISCG mount adj. geometry, replaceable derailleur hanger, 150mm travel
REAR SHOCK
Specialized AFR Shock w/ Spike valve, air spring, adjustable rebound and low speed compression, 7.875x2.25"
FORK
Specialized Future Shock e150SL, dual crown w/ integrated stem, 150mm travel, rebound, compresion and travel adjust, 25mm thru axle, alloy steerer
HEADSET
1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM
Specialized Future Shock, 31.8mm clamp integrated w/ fork
HANDLEBARS
Specialized Enduro mid rise bar, 6066 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 660mm wide
TAPE/GRIPS
Specialized thin lock on grip, dual density
FRONT BRAKE
Custom Avid Juicy 5 SL, hydraulic disc, 203mm rotor
REAR BRAKE
Custom Avid Juicy 5 SL, hydraulic disc, 185mm rotor
BRAKE LEVERS
FRONT DERAILLEUR
Shimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, mid cage
SHIFT LEVERS
SRAM X-7, aluminum 9-speed trigger
CASSETTE FREEWHEEL
Shimano HG-50, 9-speed, 11-34t
CHAIN
SRAM PC-971 w/ Power Link
CRANKSET
Shimano A/A/S 2pc custom
CHAINRINGS
22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET
Shimano M542, 2pc custom for Specialized
PEDALS
N/A
RIMS
DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUB
Specialized disc, 25mm thru axle, 32h
REAR HUB
Shimano custom M525SL hub for Specialized, 32h, alloy QR
SPOKES
DT Swiss 1.8mm stainless, alloy nipples
FRONT TYRE
S-Works Eskar, 26x2.3", 120 TPI, aramid tubeless ready bead, dual compound
REAR TYRE
TUBES
Specialized Ultralite, .6mm, presta
SADDLE
Specialized Enduro, hollow Cr-Mo rails, SL foam
SEAT POST
2014 butted alloy, single bolt setback, 30.9 x 350/400mm
SEAT BINDER
Alloy collar w/ QR, 34.9mm clamp ID
Edytowane przez olopos
