kesselll Napisano 22 Lipca 2015 Udostępnij Napisano 22 Lipca 2015 Witam, Zamierzam sobie sprawić rowerek w określonym przedziale cenowym i po jakimśtam zbadaniu rynku, upatrzyłem sobie 4 modele. Czy ktos ma może jakieś doświadczenia z nimi zwiazane, lub wie, słyszał i może podrzucic poradę. Byłbym wdzięczny. W szranki staja: VooDoo Aizan 29er OverviewApproximate Weight (KG): 14.2kgBrake Type: Hydraulic Disc BrakesForks: Suntour XCR with lock outFrame Material: AlloyGender: MensNumber of Gears: 27Pedals Included: YesSuspension: Front SuspensionWheel Size: 29"Detailed SpecsBottom Bracket: Suntour XCMCassette/Freewheel: Shimano, 9-SPD, 11-34TChain: KMC Z99Chainset: Suntour XCM 44/30/22TFork Lock-out: Yes; Lever typeFork travel: 120mmForks - Adjustable damping: YesFrame: 6061 AluminiumFront Brake: Tektro HDM290Front Hub: Formula DC-20Front Mech: Shimano Altus M370Gear Shifters: Shimano Altus M370Geometry: MTB trailGrips: VooDoo RedHandlebars: VooDooHeadset: 1 1/8th semi intergrated ball bearingPedals: Wellgo alloyQuick Release Front Wheel: YesQuick Release Rear Wheel: YesRear Brake: Tektro HDM290Rear Hub: Formula DC-20Rear Mech: Shimano Altus M370Rims: VooDoo double wall alloySaddle: VooDooSeatpost: VooDooStem: VooDooType: Mountain BikesTyre Size: 29" x 2.2"Tyres: Kenda k1080 Fuji Nevada 1.5 Disc 2015 29er , Frame:Fuji A2-SL custom-butted alloy w/ PowerCurve down tube, oversized seat tubeFork:SR Suntour SF15-XCM-HLO w/ hydraulic lockout, 100mm travelFront Derailleur:Shimano Altus, 34.9mmRear Derailleur:Shimano Alivio, 9-speedNumber of Gears:27Shifters:Shimano Altus, Rapid Fire, 8-speedChainset:Shimano Acera, alloyChainrings:44/32/22TBottom Bracket:FSA, sealed cartridge bearingCassette:Shimano HG200, 11-34T, 9-speedChain:KMC X9, 9-speedPedals:Resin platformBrakeset:Tektro HD-M290, hydraulic disc, 180/160mm rotorHandlebars:Oval Concepts flat bar, 6061 alloy, 31.8mm, 9 degrees sweep, 0mm rise, 710mm wideStem:Oval Concepts 313, 6061 3D-forged alloy, 31.8mm, 7 degrees riseHeadset:FSA 1 1/8" semi-integrated, caged bearingsRims:Vera Terra DPD22 rims 32hFront Hub:Formula CL-92 sealed bearingRear Hub:Formula CL-52 rear discFront Tyre:Vera Eos, 29″ × 2.1″, 30 tpiRear Tyre:Vera Eos, 29″ × 2.1″, 30 tpiSaddle:Oval Concepts 200 w/ steel railsSeatpost:Oval Concepts 300, 6061 alloy, 31.6, double-bolt micro-adjustWeight:14.60kg / 32.12lbs Cannondale Trail 5 29er 2015, Frame:Trail, double-butted 6061 Alloy, SAVE, 1-1/8" head tubeRear Shock:N/AFork:SR Suntour XCM-RL, 100mm, remote lockout, 1-1/8", 29"/27.5"Front Derailleur:Shimano Altus, 31.8 clampRear Derailleur:Shimano AceraNumber of Gears:27Shifters:Shimano AltusChainset:Shimano M371, 44/32/22Bottom Bracket:Tange LN 3912, square taperCassette:SunRace, 11-34, 9-speedChain:Shimano HG53, 9-speedPedals:Cannondale PlatformBrakeset:Hayes Dyno Sport hydraulic disc, 180/160mmBrake Levers:Hayes Dyno Sport hydraulicHandlebars:Cannondale C4, 6061 alloy, 20mm rise, 680mmStem:Cannondale C4, 31.8, 7 degHeadset:Tange ZstepGrips:Cannondale Dual-DensityRims:Alex DC 4.0, double wall, 32-holeHubs:Cannondale C4 DiscSpokes:Stainless Steel, 15g BlackTyres:WTB NineLine, 29/27.5×2.0″Saddle:Cannondale Stage 3Seatpost:Cannondale C3, 6061 alloy, 27.2Weight:Not SpecifiedNotes:Please Note that The Small and Xsmall size are equipped with 650b Wheels Trek Marlin 7 2015 Mountain Bike Frame:Alpha Silver Aluminium w/semi-integrated head tube, rack & mudguard mounts, G2 Geometry on 29ersFork:SR Suntour XCT, coil spring, preload, custom G2 Geometry w/51mm offset on 29ers, 100mm travel (13.5" : 80mm travel)Front Derailleur:Shimano AltusRear Derailleur:Shimano AltusNumber of Gears:27Shifters:Shimano Altus M370, 9 speedChainset:Shimano M371Chainrings:44/32/22TBottom Bracket:Sealed CartridgeCassette:Shimano HG20 11-34, 9 speedPedals:Wellgo nylon platformBrakeset:Tektro M290 hydraulic disc brakesHandlebars:Bontrager Low Riser, 31.8mm, 5mm riseStem:Bontrager Race Lite, 31.8mm, 7 degreeHeadset:1-1/8" threadless, semi-integrated, semi-cartridge bearingsGrips:Bontrager Satellite PlusRims:Bontrager AT-650 36-holeFront Hub:Formula DC20Rear Hub:Formula DC22 alloyTires:Bontrager XR1, 29×2.20″ front, 29×2.00″ rear (Bontrager XR2, 27.5×2.20″)Saddle:Bontrager Evoke 1Seatpost:Bontrager SSR, 2-bolt head, 27.2mm, 12mm offsetWeight:Not Specified Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Piotrek383 Napisano 22 Lipca 2015 Udostępnij Napisano 22 Lipca 2015 Wszystkie te rowery jak dla mnie są bardzo kiepskie. Tutaj masz dobry rower w podobnych pieniądzach -> http://esklep.intersport.pl/pl/product/114601/rower-genesis-impact-6.0-29 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Fenthin Napisano 22 Lipca 2015 Udostępnij Napisano 22 Lipca 2015 Żaden. Klasycznie polecę produkty zza zachodniej granicy: http://www.radon-bikes.de/bikes/mountainbike/hardtail/zr-team-29/zr-team-29-70 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
