wzmocnienie Specialized Carve pro pod 118 kg
lukas1
Witam jako nowy na forum,
Od 2 tygodni jestem szczesliwym posiadaczem Specialized Carve Pro 2013 xxl.
Od samego poczatku rodzi mi sie pytanie jak z wytrymlascia rowru i kompnentow- moja wago to 115-118kg.
To moj pierwszy rower od 12 lat, wczesniej mialem Gianta na sztywno i pamietam ze wyrabiala sie po czasie elementy mocowania kierownicy i widelca
Mam gorace pytanie do was dotyczxace wzmocnienia mego speca.
Jakie elementy powinienem wzmocnic ( na razie zmienilem kierwonice na low risera i manetki na Deore XT).
chcialbym go ulepszyc jak sie da :-)
Reszta wyglada tak
Frame:
Specialized M4 SL Aluminium, 29er frame w/ XC geometry, fully butted w/ smooth welding, tapered headtube and seat tube, forged post mount 160mm disc dropouts, alloy replaceable derailleur hanger
Fork:
FOX Evolution series Float 29, CTD damper, tapered alloy steerer, CTD damper, open 9mm dropout, external rebound adjust, 100mm travel
Front Derailleur:
SRAM X7, 2X10, 34.9mm clamp
Rear Derailleur:
Shimano Deore XT Shadow Plus, 10-Speed, GS cage
Number of Gears:
20
Shifters:
Shimano Deaore XT
Chainset:
Custom SRAM S1250 2pc, 10-speed XC double for 29er, GXP
Chainrings:
36/22, Aluminium
Bottom Bracket:
SRAM GXP BB for 2pc, 73mm shell
Cassette:
SRAM PG 1030, 10-speed cassette, 11-36
Chain:
KMC X-10L, 10-speed w/ hollow outer links and reusable Missing Link
Pedals:
Alloy 1pc. body and cage, w/ reflectors, 9/16"
Front Brake:
Custom Avid Elixir 5R SL, hydraulic disc w/ alloy backed super light pads, 180mm rotor
Rear Brake:
Custom Avid Elixir 5R SL, hydraulic disc w/ alloy backed super light pads, 160mm rotor
Brake Levers:
Avid Elixir 5R SL, hydraulic lever, tool-less reach adjust
Handlebars:
Flat bar, 6061 double butted alloy, 700mm wide, 10 degrees backsweep, 4 degrees upsweep, 31.8mm
Stem:
Specialized 3D forged 6061 alloy, 4 bolt clamp, 7 degrees rise, 31.8mm
Headset:
Integrated 1-1/8" upper and 1-1/2" lower threadless, Campy-style, full cartridge bearings
Grips:
Specialized BodyGeometry XCT, Kraton rubber w/ gel, closed end, 132mm, lock-on
Rims:
Carve SL Disc, 29", alloy double-wall, sleeve joint, 26mm, 32h
Front Hub:
Specialized MTB disc hub, alloy, Hi Lo flange, cartridge bearings, alloy axle, QR, 32h
Rear Hub:
Specialized MTB disc hub, alloy, Hi Lo flange, cartridge bearings, steel axle, steel cassette body, QR, 32h
Spokes:
Stainless, 2.0mm (14g)
Front Tyre:
Specialized Ground Control, 29×2.1″, Kevlar bead, 60TPI
Rear Tyre:
Tubes:
Presta valve
Saddle:
Specialized BodyGeometry Carve SL, hollow Cr-Mo rails, 143mm width
Seatpost:
Specialized 2 bolt head, forged alloy, 12.5mm offset, micro adjust, 27.2mm, 350mm or 400mm
Seat Binder:
31.8mm, forged alloy QR, brass washer
