AMR7700 Napisano 19 Czerwca 2014 Napisano 19 Czerwca 2014 Witam Chce zamontowac nowe w miare lekkie kola (26 cali) ,odpowiednie do tras znajdujacych sie w Holandii , czyli lekkie i przyjemne , bez kamieni , z mala iloscia korzeni, wszechobecny piasek. Znalazlem dwa potencjalne modele: Sram roam 50 : It’s everything the modern mountain biker could ask for. One of the lightest alloy trail wheels in the market, ROAM 50 delivers a smart balance of weight, inertia and stiffness—making for a very responsive and predictable wheel. Thanks to our WIDE ANGLE rim, its tire profile delivers superior traction. Intended use: XC/TR Available in all 3 wheel sizes: 26, 27.5 and 29in Lightweight aluminum rim with asymmetrical TAPER CORE profile WIDE ANGLE profile: 21mm inside, 25mm outside rim width UST compatible Available with 11-speed XD™ Driver Body, 10- or 9-speed driver body Aluminum nipples with nylon lock ring SOLO SPOKE design with double butted, lightweight steel spokes Durable hub internals with Star Ratchet system SIDE SWAP easy conversion to all axle types DOUBLE-DECKER hub shell design Weight: 1475g (26in), 1530g (27.5in), 1610g (29in). Wheel pair in lightest configuration. Wheel weights can vary 5%. opcja 2 : Dt Swiss 1501 spline The DT Swiss XR-1501 SPLINE ONE wheels are meticulously engineered using cutting edge components and DT-Swiss's legendary reliability creating the ultimate XC riding experience Wide, tubeless ready disc specific rims are extremely light weight (18x24mm) SPLINE ONE hubs allow for an optimized spoke anchor points with stainless steel bearings, DT Swiss patented Star Ratchet System and International Standard 6-bolt disc mount SPLINE ONE wheels include 36 teeth Star Ratchet System for quick engagement and starting speed DT Swiss straight pull double-butted bladed spokes with ProLock nipples *Front 15x100mm T-A to 9x100mm QR and rear 12x142mm T-A to 10x135mm QR conversion kits included Tubeless valves included in both front and rear wheels and rear wheels include roll of tubeless rim tape enough for 2 wheels waga 1400g Waze okolo 82kg bez plecaka i reszty bebechow. Czy ktos z was uzywa tych kolek? Dzieki za pomoc.!! sram roam 50 : http://flowmountainbike.com/tests/tested-sram-roam-50-29er-wheelset/ dt swiss 1501 spline one : http://www.dtswiss.com/Wheels/MTB-Wheels-/XR-1501-Spline-ONE-26
dawid Napisano 20 Czerwca 2014 Napisano 20 Czerwca 2014 A nie zastanawiałeś się nad składaniem? wyjdzie trochę lżej i zdecydowanie taniej, chyba że masz te koła w jakiś wyjątkowych cenach do kupienia Pozdro
