7 tys zl FELT Compulsion 50
bull303
10506-37374-full-compulsion-50-v2-int-20
Frame Felt Compulsion Equilink aluminum All Mountain series, adjustable 150/160mm travel suspension frame: set at 150mm double butted/hydroformed 6061 aluminum front and rear triangle, Equilink suspension technology, ControlTaper semi-integrated head tube, intergrated ISCG mount, ammerschmidt/adjustable seatpost cable guides, Hi clearance aluminum seat and chainstay yokes, bolt on kevlar chain watcher, replacable derailleur hanger. Felt/Shimano 142 x 12mm E-Thru dropouts w/Shimano SM-AX75 QR axle
Rear Shock: RockShox Monarch R HV : solo air spring, hydraulic damping w/IFP and rebound adjustment, w/custom valving Forks RockShox Sektor TK Solo Air 15 150mm travel: w/turnkey lockout: 15mm Maxle lite thru axle, tapered aluminum steerer, all travel solo air, adjustable rebound, magnesium lowers w/post style disc mount Rear Derailleur Shimano Deore XT RD-M780 10 speed: long cage Front Derailleur Shimano SLX FD-M661-10 10 speed: bottom swing Shifters Shimano SLX ST-M660-10 10 speed Rapid Fire Chainset Shimano XT FC-M780 3x10: aluminum arms, composite middle ring 42tx32tx24t chainrings sizes Bottom Bracket w/crankset Chain Shimano HG-74 10 Speed Freewheel Shimano HG-81 10 Speed 11-36T Headset Fully Integrated 1-1/8”/1.5” Aheadset for tapered head tube: Cane Creek sealed cartridge bearing, w/Felt Tornado aluminum top cap Stem Felt MTB All mountain stem 3D-forged design: 4-boltsplit handlebar clamp, 1-1/8” threadless, for 31.8mm handlebar, 7 degree rise, w/stainless hardware Handlebars Felt MTB All mountain 25mm riser bar: butted 6061 Aluminum, 9 degree bend, 5 degree up sweep 31.8mm bar bore Front Brake Avid Elixir 1 hydraulic disc brake: w/200mm rotors Rear Brake Avid Elixir 1 hydraulic disc brake: w/180mm rotors Brake Levers Avid Elixir 1 Rims WTB Speed disc I23 doublewall w/single eyelets, 32H Front Hub Felt Forged/CNC aluminum, 6 bolt disc mount for 15mm thru axle Rear Hub Felt forged aluminum 12 x 142mm thruaxle 6-bolt disc mount, 10 speed cassette w/o quick release lever Spokes Stainless double butted 14g/15g w/aluminum nipples Tyres Continental Mountain King II SL 2.4 folding bead Saddle Felt All mountain design low profile saddle w/hollow cromo rails Seatpost Felt aluminum 2-bolt micro adjust butted 6061 aluminum shaft, low-profile forged head & forged rail clamps
Seat Post Clamp: Felt qr style: seat clamp cold forged + cnc, 6061 aluminum Grips Felt All Mountain double aluminum clamp lock-on wing grips Miscellaneous
Bar Ends: Felt Wing Icon end plugs
Cables: Custom Felt brake and derailleur cable set featuring stamped Felt logos & FELT rubber 2-tone tube tops at head tube and one CNC aluminum ferrule at RD.
Rowerek do enduro cena 7tys zl. Dobry stosunek jakosci do ceny. Co sadzicie o tym rowerku?
