Cześć. Zakładam temat gdzie będziemy pokazywać swoje rowery. Tak więc zaczynam od siebie.
Wybór padł na Specialized Carve Expert 2013
Zdjęcia:
Opis:
Specyfikacja techniczna
Rama
Specialized M4SL Aluminum, 29er frame w/ XC geometry, fully butted w/ smooth welding, tapered headtube and seat tube, forged post mount 160mm disc dropouts, alloy replaceable der. hanger
Amortyzator
Widelec
RockShox Reba RL 29", TurnKey damping w/ Push-Loc remote lock out, Solo Air spring, tapered alloy steerer, 32mm alloy stanchions, external rebound adj., 100mm travel
Stery
Integrated 1-1/8" upper and 1-1/2" lower threadless, Campy-style, full cartridge bearings
Mostek
Specialized 3D forged 6061 alloy, 4 bolt clamp, 7º rise, 31.8mm
Kierownica
Flat bar, 6061 double butted alloy, 700mm wide, 10º backsweep, 4º upsweep, 31.8mm
Chwyty kierownicy
Specialized Body Geometry XCT, Kraton rubber w/ gel, closed end, 132mm, lock-on
Przedni hamulec
Avid Elixir 3R, hydraulic disc, G2 CleanSweep 180mm rotor
Tylny hamulec
Avid Elixir 3R, hydraulic disc, G2 CleanSweep 160mm rotor
Dźwignie hamulcowe
Avid Elixir 3R, hydraulic lever, tool-less reach adjust
Przednia przerzutka
SRAM X7, 10-speed 2X10, 34.9mm clamp
Tylna przerzutka
Shimano Deore XT Shadow, 10-Speed, GS cage
Manetki
Shimano Deore, 10-speed Rapidfire plus, SL type
Kaseta
SRAM PG 1030, 10-speed cassette, 11-36
Łańcuch
KMC X-10, 10-speed w/ reusable Missing Link
Mechanizm korbowy
Wieńce
36/22, aluminum
Suport
SRAM GXP BB for 2pc, 73mm shell
Pedały
Alloy 1pc. body and cage, w/ reflectors, 9/16"
Obręcze
Carve SL Disc, 29", alloy double-wall, sleeve joint, 26mm, 32h
Przednia piasta
Specialized MTB disc hub, alloy, Hi Lo flange, cartridge bearings, alloy axle, QR, 32h
Tylna piasta
Specialized MTB disc hub, alloy, Hi Lo flange, cartridge bearings, steel axle, steel cassette body, QR, 32h
Szprychy
Stainless, 2.0mm (14g)
Przednia opona
Specialized Ground Control, 29x2.1", Kevlar bead, 60TPI
Tylna opona
Dętki
Presta valve
Siodło
Specialized Body Geometry Carve SL, hollow Cr-Mo rails, 143mm width
Sztyca
Specialized 2 bolt head, forged alloy, 12.5mm offset, micro adjust, 27.2mm, 350mm or 400mm
Zacisk sztycy
31.8mm, forged alloy QR, brass washer
