Napisano (edytowane)
Kolejny przedstawiciel "polskiej" myśli technicznej.
Bar Ends: (Rogi)....................................................Boplight........................59
Bottle Cage: (Koszyk na bidon)..............................NN................................42
Brake (Front): (Hamulec przedni)...........................Avid Elixir R..................307
Brake (Rear): (Hamulec tylny)................................Avid Elixir R..................318
Cables: (Pancerze i linki)........................................NN................................72
Cassette: (Kaseta)................................................ Shimano SLX 11-32......291
Chain: (łanńuch)....................................................Shimano HG53.............273
Crankset: (Korby....................................................Truvativ FireX...............902
Derlr (Front): (Przerzutka przednia).......................Shimano LX..................171
Derlr (Rear): (Przerzutka tylna)..............................Shimano LX..................304
Fork: (Widelec)......................................................Rock Shox Tora 318.....2110
Rotor (Front): (tarcza przednia).............................Ashima Aro-08..............96
Rotor (Rear): (tarcza tylna)....................................Ashima Aro-08.............120
Frame: (Rama)......................................................Kross Level A6.............1912
Grips: (Gripy).........................................................KCNC Eva....................13
Handlebar: (Kierownica)........................................Truvativ Team................149
Headset: (Stery)....................................................Cane Creek...................wliczone do wagi ramy
Pedals: (Pedały)....................................................CB Egg Beater C...........287
Seat: (Siodło).........................................................Pro Condor...................203
Seatpost: (Sztyca).................................................Boplight 400mm.............228
Seatpost clamp: (Zacisk sztycy).............................NN.................................19
Shifters: (Manetki).................................................Shimano SLX.................272
Skewers: (Zaciski koł)............................................Dartmoor Bolt-on...........61
Spacers: (Podkładki pod mostek)..........................Accent Carbon...............8
Stem: (Mostek)......................................................Truvativ Team................148
Tire (Front): (Opona przednia)..............................Schwalbe RaRa.............454
Tire (Rear): (Opona tylna).....................................Schwalbe RaRa.............446
Top Cap: (Top cap)................................................Aest...............................10
Tubes: (Dętki)........................................................Maxxis Ultralight.............216
Wheel Front: (Koło przednie).......................................................................678
-Hub: (Piasta)........................................................Novatec D711SB
-Rim: (Obręcz).......................................................Remerx Magic
-Spokes: (Szprychy)..............................................CN Spoke Aero424
-Nipples: (Nyple)....................................................Sapim Polyax
Wheel Rear: (Koło tylne)..............................................................................810
-Hub: (Piasta)........................................................Novatec D712SB
Suma:...........................................................................................................10979
Docelowo w rowerze ma znaleźć się Reba oraz przy najbliższej wymianie napędu, tylna przerzutka Sram plus Gripshifty. Obecny napęd powinien ten rok spokojnie wytrzymać.
Myślę, że granica 10 kilogramów jest do osiągnięcia :)
Zdjęcia będą po weekendzie majowym.
Edytowane przez michaljg
Mam pytanko, Jak się sprawują obręcze i pod jaką wagą jeżdżą ?;D Bo jest na BS ten zestawik co Ty masz ale nie znalazłem żadnych opini dotyczących obręczy.
Pozdrawiam Olomaster
Ja również nie znalazłem o nich żadnych opinii, jedynie w języku czeskim można coś przeczytać. Ktoś musi być królikiem doświadczalnym :D Na razie nie mogę nic o nich powiedzieć, ponieważ doszły do mnie dopiero wczoraj, mają zrobione raptem 15km do pracy i z powrotem. Remerx na pewno nie zaniża specjalnie wagi obręczy, bo mój zestaw wyszedł poniżej 1500g, a tego się nie spodziewałem.
Tak, składali mi je właśnie w Bikestacji. Gotowe zestawy mają inne szprychy.
Znośnie, spokojnie w trzech cyfrach się mieszczą.
Jedynie naklejki na obręczach trochę "krzyczą", zastanawiam się nad zdjęciem ich, przynajmniej po jednej na stronę. Następne chwyty raczej też będą nieco bardziej stonowane :)
Hmm, rzeczywiście, korba powinna ważyć więcej - sprawdzę to przy najbliższej rozbiórce. Mogła się o coś oprzeć, albo suport accenta waży mniej od oryginalnego?
  • 1 miesiąc temu...
Koła przejechały kilkaset kilometrów, nie sprawiały dotąd żadnych problemów. Ale pomimo, że ważę ponad 80kg, chyba nie mają ze mną trudnego życia - jeżdżę zachowawczo i ostatnio głównie po asfalcie. Dopiero na ten weekend zakładam opony terenowe.
Ja jestem z obręczy zadowolony, ale nie mam porównania do żadnej innej w podobnej cenie, także nie chciałbym wydawać wyroków. Dla mnie mogłaby być nieco szersza, ale taki urok lekkich obręczy w niskiej cenie.
  • 2 miesiące temu...
Tylne koło po około 2000km poszło pierwszy raz do centrowania, dostało minimalne bicie boczne. Przednie koło na razie nie wymaga ingerencji.
Zawitały nowe, estetyczne gadżety: Kierownica New Ultimate Carbon Super Light, waga realna 107g oraz węglowy korek sterów :) W związku z tym poprzednia kierownica i korek idą na sprzedaż.
Zimą będę się rozglądał za amortyzatorem, ale chyba bez manetki, bo tylko przeszkadza na kierownicy - chętnie przesunąłbym manetki i klamki jeszcze centymetr do środka a brakuje miejsca.
Mi coś nie pasuje w specyfikacji kawałek z tarczami ...
Na foto nie wygląda żeby tył był większy od przodu :) a waga wyraźnie to sugeruje.
Wagę całości podałeś jako suma poszczególnych elementów czy ważyłeś cały rower ... bo wygląda mi coś za lekko :)
Pozdro
Piksel, Węglowe elementy mają cieszyć oko, zbicie wagi to tylko efekt uboczny. Rama zostaje, co z tego, że ciężka, skoro mam do niej sentyment :)
Przednia tarcza ma 180mm, tylna 160mm. Waga roweru to suma elementów, całości nie ważyłem.
Sentyment, sentymentem, ale jaki jest sens ładowania kiery kosztującej podobną kwotę do ramy?
  • 7 miesięcy temu...
Rower zważony na wadze podwieszanej. w tej konfiguracji, ale na oponach Rubena Zefyros (443g oraz 448g), owijce szosowej, z uchwytem na pompkę i bez rogów wyszło 10,98kg :)
Ze zmian - jedzie do mnie siodło Max SLR Gel Flow, założyłem chwyty ESI Extra Chunky, mostek New Ultimate 100mm, aluminiowe śruby w korbie i szukam Reby w dobrym stanie i dobrej cenie. Na tym byłoby koniec zmian, do czasu, aż napęd wyzionie ducha :)
Koła na bikestacji kupiłeś jak zgaduje ? Sam się do nich przymierzam więc jak możesz to dodawaj wpisy w razie gdyby były z nimi problemy ;) Rama faktycznie trochę nie pasuje do całości a kiera czy aby na pewno bezpieczna przy Twojej wadze ? Jaka to jest szerokość bo waga bardzo niska przyznam.
Szerokość kierownicy to 600mm. Na razie służy, a jadąc stresu nie odczuwam. Jeśli nie będzie poważniejszej gleby, powinna bez problemu wytrzymać. Teoretycznie.
Tak, koła są z Bikestacji. Do tej pory nie mam z nimi problemów, oprócz pewnego serwisu. Panowie chyba pierwszy raz widzieli płaskie szprychy i centrując koła zrobili ze szprych świderki. Po własnoręcznej poprawce do dzisiaj koła (i szprychy :P) są proste.
