[opony] duro stinger
krawiec71
Czy ktoś z kolegów posiada lub jeżdził na tej oponie.Co o niej sądzicie. Czy warto ją kupićhttp://biketires.pl/product-pol-3646-Opona-szosowa-Duro-Stinger-700x23C-czarna.html lub Opona szosowa Duro Stinger 700x25C czarna | 700C - szosa - dętkowe zwijane | BikeTires.pl - Opony Rowerowe, Koła Rowerowe, Maratony MTB
Rozważam zakup 23 lub 25 co radzicie
poprawiłem nazwę tematu by była zgodna z regulaminem. Używamy kwadratowych a nie okrągłych nawiasów np [.....]
Jedyna recenzja, jaką znalazłem:
"These are promoted as all-purpose racing and training tires. They are suitable for all conditions and the 127 TPI ensures a fast roll rate at 120 PSI. I was also very impressed with these tires and their durability. They do look a little ‘fat’ and have some good tread, but they roll very well. I have even used them in a few races and they have handled well and seem to be quick over all kinds of surfaces. They are hard wearing and I have seldom punctured, however the puncture rate is higher than the Slickster Forcefields (having only punctured twice on the Slickster Forcefields). The Duro Stingers have been mostly used on my rear wheel and as a result have worn out a little quicker. After five months of solid training and racing usage, I had to discard one tire recently as a small hole had formed and the inner tube was starting to push through it. It was also getting worn on the side-walls and thus definitely needed replacing. I replaced with an identical Duro Stinger and believe that this is my training tire of choice. I can ride anywhere without worrying too much about getting punctures. They are hard wearing and handle exceptionally well in wet conditions with their treads. They are relatively smooth on the top which means that for road racing they would roll quickly and efficiently; and grip the surface as you corner." ( skopiowane stąd: Bikedan's Product Review: Duro Tires | Bikedan in Asia )
Lekka jak na tę cenę, według recenzji w miarę odporna na przebicia, trwała (po pięciu miesiącach intensywnego treningu i wyścigów dziura na wylot i zużyte boki - zależy, co autor rozumie pod pojęciem "intensywny", więc trochę trudno stwierdzić, czy to dobry wynik) i dobrze się trzyma na mokrym. Może warto spróbować czegoś mniej znanego (bo ja prawdę mówiąc nie zauważyłem, żeby ta firma była często wspominana przy okazji dyskusji o oponach/kołach).
