[29er]Co wybrać?
tomcioo85
Witam wszystkich forumowiczów
Jako iż jestem laikiem z tematów "rowerowych" :) mam prośbę o pomoc w wyborze roweru 29 cali z kolekcji na 2012 rok. Chciałbym kupić rower w cenie do 3000zł. Moje typy to: Scott Aspect 29 sport, Cube Analog 29 i Trek Mamba 29.
Scott:
WEIGHT
13.70 kg / 30.18 lbs
FRAME
Aspect 29 Alloy 6061 D.B., Performance
geometry, Integrated headtube
FORK
Suntour XCR, with Lockout, 100mm travel
HEADSET
Ritchey Logic OE integrated
DERAILLEUR (REAR)
Shimano Deore, RD-M592, 27 Speed
DERAILLEUR (FRONT)
Shimano Alivio, FD-M430, 34.9mm
SHIFTERS
Shimano Alivio, SL-M430, R-fire plus 2
BRAKE LEVERS
Shimano BL-M445 Disc
BRAKES
Shimano BR-M446 Disc, Hydr. Disc
CRANKSET
Shimano FC-M430-8, silver, 44Ax32x22 T
BB-SET
Shimano BB-ES-25
HANDLEBAR
Scott Aspect OS, 640mm, black, 31.8mm,
15mm rise, 8° backsweep
H'STEM
Scott Comp JD-ST57 A
PEDALS
Wellgo C 128
SEATPOST
Scott Comp, 31.6mm
SEAT
Scott Aspect
HUB (FRONT)
Scott Disc Team CL
HUB (REAR)
Shimano FH-RM 35 CL
CHAIN
KMC X9
CASSETTE
Shimano CS-HG50-9, 11-32 T
SPOKES
15 G, stainless, black
RIMS
Araya DS-700 Disc, 32H, black
TIRES
Schwalbe Rapid Rob, 29 x 2.25, 50TPI
Cube:
white 'n' black
Suntour XCM 29 Lockout 100mm
FSA No.10 semi-integrated
Easton EA30 Oversized
Easton EA30 Lowriser Oversized
CUBE Performance Grip
Shimano Deore RD-M592 Shadow
Shimano SLX FD-M661 Direct Mount, 9-speed
Shimano BR-M445 hydr. discbrake(160/160mm)
Shimano FC-M430 44x32x22T, 175mm, 3x9 speed
RFR ZX24 29
Alex ZX 24 29
Shimano HB-RM66 Disc
Shimano FH-RM66 Disc
DT Swiss Industry 2.0
Schwalbe Rapid Rob Performance 29x2.25
Schwalbe MTB AV19 29
Fasten Alu
Scape Active 8
Easton EA30 30,9mm
Scape Varioclose 34.9mm
13,9 kg
Trek:
Frame
Alpha Gold Aluminum, butted & hydroformed tubing, cold-forged dropouts & bottom bracket, G2 Geometry
Front suspension
RockShox XC32 w/coil spring, TurnKey lockout, custom G2 Geometry, 51mm offset crown, 100mm travel
Sizes
15.5, 17.5, 19, 21, 23"
Wheels
Wheels
Shimano M35 alloy hubs; Bontrager AT-850 disc 29 32-hole rims
Tires
Bontrager 29-3, 29x2.1"
Drivetrain
Shifters
Shimano Alivio M430, 9 speed
Front derailleur
Shimano Acera
Rear derailleur
Shimano Deore M591
Crank
Shimano Alivio M4308, 44/32/22
Cassette
Shimano HG20-9 11-34, 9 speed
Pedals
Wellgo ATB, boron axle, steel cage
Components
Saddle
Bontrager Evoke 1
Seatpost
Bontrager SSR, 27.2mm, 20mm offset
Handlebar
Bontrager Low Riser, 31.8mm, 5mm rise, 9 degree sweep
Stem
Bontrager Race Lite, 31.8mm
Headset
1-1/8" threadless, semi-integrated, semi-cartridge bearings
Brakeset
Shimano M446 hydraulic disc brakes
Czym się kierować w wyborze roweru.
Z góry dzięki za pomoc.
Tomek
