Jakoś tak wychodzi. :teehee:
Bar Ends: (Rogi) ..............................................BBB 127 g
Bar Plugs: (Korki do kierownicy) .......................BBB w masie kierownicy
Bottle Cage: (Koszyk na bidon) n.a.
Brake (Front): (Hamulec przedni) ......................Hayes HFX9 XC (całość: klamki, przewody, tarcze 160mm) 434g
Brake (Rear): (Hamulec tylny) ..........................Hayes HFX9 XC (całość: klamki, przewody, tarcze 160mm) 445g
Brake Levers: (Klamki Hamulcowe)
Cables: (Pancerze i linki) ..................................Clarks OEM 71g
Cassette: (Kaseta) ...........................................Shimano LX CS-M580 386g
Chain: (Lancuch) .............................................Shimano HG73 283g
Crankset: (Korby) ...........................................Shimano Hone FC-M600 170mm 927g
-Crank Arms: (Ramiona)
-Bottom Bracket: (Suport)
-Outer Ring: (Blat)
-Middle Ring: (Srednia tarcza)
-Inner Ring: (Mala tarcza)
-Crank Bolts: (Sruby mocujace tarcze)
Derlr (Front): (Przerzutka przednia) ...................Shimano XT FD-M770 2008 154g
Derlr (Rear): (Przerzutka tylna)..........................Shimano XT 266g
Fork: (Widelec) ................................................RS Reba Team U-Turn 1680g
Rear Shock: (Damper) Fox RP23
Frame: (Rama) ................................................SC Superlight (S) + damper 2285g
Grips: (Gripy) ..................................................BBB BHG-28 30g
Handlebar: (Kierownica) ...................................Tioga DL2000+korki BBB 185g
Handlebar Tape: (Owijka) n.a.
Headset: (Stery) ..............................................Ritchey pro logic (top cap, masa gwiazdki w masie amora) 131g
Pedals: (Pedaly) ..............................................Shimano PD-M540 357g
Seat: (Siodlo) .................................................Selle Italia Prolink 285g
Seatpost: (Sztyca) ..........................................Race Face Ride 30,9mm 313g
Seatpost clamp: (Zacisk sztycy) .......................w masie ramy
Shifters: (Manetki) ..........................................Shimano Deore 272g
Skewers: (Zaciski kol) .....................................Shimano M525 128g
Spacers: (Podkladki pod mostek)
Starnut: (Gwiazdka)
Stem: (Mostek) ..............................................Tioga O-Bone 100mm 147g
Tire (Front): (Opona przednia) .........................Schwalbe Fast Fred 2.0 347g
Tire (Rear): (Opona tylna) ...............................Schwalbe Fast Fred 2.0 352g
Top Cap: (Top cap) .........................................Ritchey pro logic
Tubes: (Detki) ................................................Michelin AirComp Ultralight+Schwalbe SV14 276g
Wheel Front: (Kolo przednie) ............................................................................994g
-Hub: (Piasta) .................................................Shimano HB-M525
-Rim: (Obrecz) ................................................Mavic XM117
-Spokes: (Szprychy) ........................................NN
-Nipples: (Nyple) .............................................NN
-Rim tape: (Opaska) ........................................Maxxis
Wheel Rear: (Kolo tylne) ................................................................................
...1102g
-Hub: (Piasta) ..................................................Shimano FH-M525
Misc Option: (Inne) ..........................................RS Poplock 70g
Suma ................................................................................
.............................12072g
  • 1 miesiąc temu...
yagoolar, będą te fotki, może coś bym podpatrzył do siebie, ciekawy jestem jak ten mostek się prezentuje na całości. Sam muszę wymienic swój na 100mm i się zastanawiam czy ładować kase w coś od syntace, boplight, różnica w cenie kolosalna, ale może wytrzymałość lepsza.
  • 3 miesiące temu...
